Just checking that I got this correct. I’m in Australia.
  • What do the instructions say? I've searched the web for that product but it's not popping up. Mar 9, 2020 at 6:14
  • I would guess that you have it correct - most things like inline tend to keep the same terminal orientation...
    – Solar Mike
    Mar 9, 2020 at 6:43
  • both brown wires appears to be on the wrong side of the screw ... the end of a wire should wrap around the screw in a clockwise direction
    – jsotola
    Mar 9, 2020 at 6:56
  • Thanks for the help! I consulted an electrician friend, he said wiring was good just a bit sloppy. I trimmed them up and it works!
    – Vanderhaka
    Mar 9, 2020 at 8:57
    Hello, and welcome to Home Improvement. Would you add your results as an answer? And, you should probably take our tour so you'll know you'll know the details of contributing here. Mar 9, 2020 at 11:05
Regarding the DETA Smart Inline switch, in Australia, this above pictured wiring is correct, if not a bit messy, cleaned up the connections and it works perfectly.
