I am about to install my frameless shower door and realized I am missing the stud by two inches I have two layers of 1/2 cement board and have found some anchors that can hold 600lbs will this be enough support the door weighs about 80lbs
2600lbs but the continuous vibration of shutting the door is not the same as supporting a shelf etc– Solar MikeMar 3, 2020 at 20:33
1You'll probably be fine, but more details on the anchors (picture) would be good. You could have totally the wrong thing and we wouldn't know.– JPhi1618Mar 3, 2020 at 20:35
homedepot.com/p/…– charlesMar 3, 2020 at 22:09
4I decided I don't want to deal with any problems down the road so im ripping out the wall next to the shoer and will slide a couple 2x4's for support– charlesMar 3, 2020 at 22:11
4Probably the safest bet to do it that way, write it up as an answer and accept it to close out the question.+– Ed BealMar 3, 2020 at 22:50
Add a comment
