I usually see fireplaces that are open only on one side. This would be a standard example:
https://hips.hearstapps.com/hmg-prod.s3.amazonaws.com/images/fireplace-with-fire-burning-royalty-free-image-75406522-1541632053.jpg
The flames are surrounded by 3 walls and open on the one viewing side. Recently I've noticed some fireplaces such as:
https://www.mason-lite.com/wp-content/uploads/2011/08/THREE-SIDED.jpg
http://www.mason-lite.com/wp-content/uploads/2015/09/Western-Fireplaces-7-3-wLogo-1.jpg
https://i.pinimg.com/originals/af/68/aa/af68aaae13686134c06bce0da4c03947.jpg
These are open on three sides. Does this mean it would be possible to have a fireplace in the middle of a room that is completely open on all sides, with only a chimney? I suspect you would want some sort of protective screen for debris and such.
Yes - examples are out there. For practical reasons the chimney tends to be metal, or in older buildings, just a smokehole in the roof.
enter image description here enter image description here enter image description here enter image description here
    Can you elaborate that no form of mechanical ventilation is required? Two of the examples you show are surrounded in glass, which I don't think count towards the idea of an open fireplace. I would have thought smoke would get into the rooms if there's really no walls around it, but looks like I was wrong. Very cool!
    – Behacad
    Commented Mar 1, 2020 at 1:33
  • Chimneys (aka "natural draft" so no mechanical ventilation) work so long as the principles applicable to chimneys are respected.
    Commented Mar 1, 2020 at 2:14
it's a simple matter of draft, and is the same way the traditional home brick fireplace like this works:
once heat is generated, and if the chimney goes high enough, an updraft is generated which is where all the smoke from combustion will go. In an open on all sides wood burning fireplace as long as the fire [pit] diameter is smaller than the chimney hood above it then all smoke will travel up that chimney. If you got a strong wind within the room then it can obviously blow smoke outside of the chimney draft and get into the room.
The protective screens... for wood burning fireplaces or pits is likely needed, and probably required by building code. Per your first pic of a traditional home wood fireplace, they usually do. I can remember embers from crackling wood flying out 5' onto the carpet even through the wire mesh screen, which is probably what led to the glass doors.
Place like a ski lodge, with a big concrete wood fire pit in center of room, with concrete floor and no combustible material near it, and a ~5' distance preventing people from easily getting next to the fire, is the shield. The updraft works the same.
gas fireplace with fake wood (which is what your pics are) produce basically no smoke the draft would work the same way which is where all the CO and CO2 and other clean combustion gases would go. I doubt those pics are of wood burning center room fireplaces... the type of people owning places like that would never dirty their hands touching cut wood much less carry it inside, those are gas fireplaces so it's much safer than wood. So that's how you can have an open design fireplace/firepit in the center of the room open on all sides, it's either natural gas or propane. And then I would assume local building code would provide various requirements as to what's acceptable.
    Ok, so you can have open gas fireplaces too? Cool. Also, careful with the "the type of people owning places like that" comment. Not sure what you're referring to. Poor people, rich people, artsy people, simple folk, and people of all types like wood flames. Also, I know for a fact at least one fireplace I linked if a wood fireplace.
    – Behacad
    Commented Mar 1, 2020 at 2:24
