9
This is an anecdote I've heard from time to time, but have not read any systematic evidence for.
Given that a geometrically perfect door fitting would be difficult (if not impossible) to achieve, are there any proven methods to minimise asymmetric load-bearing on a heavy 3-hinge door?
  • 10
    Maybe at first if not we’ll aligned but as the hinge wears they will have close to the same loading.
    Feb 25, 2020 at 19:49
    A common (and painful!) homework assignment in introductory Mechanics (physics) courses is to draw the force diagram for a 2-hinged door or equivalent :-) Feb 25, 2020 at 20:22
    Is there a particular reason you want this?
    – Mast
    Feb 26, 2020 at 7:05
    Why you want to minimise asymmetric load-bearing. As long as you put it up right, the differences should already be minimal enough not to matter in a home environment.
    – Mast
    Feb 26, 2020 at 7:31
  • 5
    I don't see anything wrong with improving your understanding in any specific trade or skillset. I think we've also had two fairly decent answers on the topic so far.
    – Brybeck
    Feb 26, 2020 at 8:49
14
The best method of reducing the chance of putting more stress on one hinge vs another is to use prehung doors. Your question is the number one reason why most doors that are installed are prehung.
The fact is they can have a machine cut the hinge cutouts on the jamb to pretty close perfection (you can look at a prehung door for about 1 second to tell if there are angling issues on the hinges) and then have the matching cutouts on the door side.
Let me tell you with too much unwanted experience that measuring perfectly, taking your time and using the right tools to install a door perfectly "square" might be skill but includes a degree of luck and compromise.
As far as what hinge has the most weight on it... It is based on how it was installed and quite possible the wall it was installed on (walls aren't 90 degrees most of the time) but it really doesn't matter. The most important aspect of "hinge" weighting in residential doors is your top hinge with the jamb side being more important than the door side.
A door's weight is resting on the cutout grooves on jamb and door. There is literally no real force and most hinges could carry 100 times the weight (without the door swinging). The problem comes when weight is added to the door and this is often someone hanging on the door handle or the top of the door while it is moving. This will produce an outward force and will affect the top hinge the most. This is why you want to screw the top hinge into the studs not the jamb.
So to answer it concisely - no there isn't one hinge bearing the weight and unless your hinges are floating in the cutout. And the weight is usually inconsequential. The top hinge however has the most chance to fail due to improper installation or abuse.
The math - I don't want to get deeply into the math on this but what we are talking about is torque which measures the amount of force applied as something is moved over a pivot. So a door has 2-3 hinges.
The equation for applied torque on them has basically three components. The weight of the door, the center of the weight of the door, and the height of the pivots - which is used as the angle differential of the center of mass. The greater the height vs the center of the weight the greater the torque. What I mentioned above about the common failures of the top hinge is greatly effected by a human interaction.
This is because if you gently open or close a door by applying a force perpendicular to the door the only weight that matters is that of the door. The top hinge already is bearing most of the applied torque in this equation only because of its height.
However this is highly amplified if someone leans on the knob as they move the door because the center of the mass not only gets lower but it gets more outward which makes for a great angle comparatively for the top hinge. This is a basic door swing torque physics equation, however the real life "measurement" is hard because the person opening the door is rather inconsistent with the pressure they apply.**
    And because the torque (vertical plane) on the top hinge is greater. Draw the force diagram. Feb 25, 2020 at 20:24
  • @CarlWitthoft - if you guys want a diagram and physics - I will do the math but might bore the crap out of you.
    – DMoore
    Feb 25, 2020 at 20:47
  • I was commenting more to encourage the doubters to see for themselves how/why the hinges take on loads. I agree it's beyond scope of DIY Feb 26, 2020 at 13:13
    It's worth mentioning that only some hinges rest on mortises. Most of them actually bear on the screws, with the mortises being slightly oversized for easier installation. Heavier commercial doors may have play in the mounting that allow the hinge leaves to settle onto the mortises, but many do not.
    Feb 26, 2020 at 13:56
  • Even when no weight is added to the door, the weight of the door itself pulls on the top hinge and pushes on the bottom hinge. There isn't enough weight in the door itself to deform the hinge or jamb, but heavy doors can weigh enough to, over time, pull on the screws that hold the top hinge in. Feb 26, 2020 at 21:27
11
If you're referring to vertical loading, you'll never get that perfect. However, with a bit of time they'll equalize due to wear on the hinge leaves.
Now if you're talking about lateral loads, you can't do anything about that. The top hinge naturally has more tension on it, barring any misalignment of the other hinges at a give swing angle, and the bottom hinge has a roughly equal amount of compression on it.
If it's really a concern, put ball bearing hinges on and don't worry about it for a decade or so. No one else does (within the realm of residential and light commercial construction, anyway--if you're building a vault you're on the wrong website).
  • I don't understand the hinge leaves changing. How does a flat piece of metal change? I am not sure I have ever seen a "warped/changed" hinge leaf in a residential house. I have seen a bent one hold a 500 pound commercial door. How does a leaf change?
    – DMoore
    Feb 25, 2020 at 19:44
    Are you referring to the wear I mentioned in the first paragraph? Take a look at the hinges on a commercial building that's a few decades old sometime. You'll see gaps in the leaves where they've worn away. Sometimes it's a quarter inch or more. You'll often see accompanying wear on the threshold where the door has sagged.
    Feb 25, 2020 at 19:47
  • 4
    Just to clarify, the part that wears is the "bearing" surfaces in the round part that holds the pins. The circular bearings rotate on each other and if there is more than it's fair share of pressure, it will wear until the pressure is equalized. Not the flat parts you screw to the jamb.
    – Tim Nevins
    Feb 25, 2020 at 19:50
  • I agree I put as a comment because I figured many would not have experienced the metal wear or noticed it. +
    Feb 25, 2020 at 19:52
    Again, I didn't say anything about warping. We're talking about wear (grinding away of metal). The mortises are irrelevant as this occurs between leaves.
    Feb 25, 2020 at 20:10
