I forced my drill too much when using in a drill guide so something strange happened to the chuck. At first it didn't turn easily to lock and unlock there were click sounds when I was trying to turn it with the help of lock button at the top, then now it completely stopped turning so I have to replace it.
I tried the traditional method mentioned on manual ( using an Allen key) but not working. I took it to the service and the man there couldn't do that with the same method. And he said I have to open this up to remove the chuck and he wanted to charge me a little more to do it. So I didn't want it. I decided to remove it myself.
I opened that before to remove the chuck but I couldn't find a way. Is it easy to remove it after opening up the casing? If so how? Could anybody help? Thanks in advance.
Inside
  • Great pic - I expect they wanted to open it to get access to the shaft or to hold the back of the chuck. I haven't had one of these apart, but lets see if someone else can tell you what to do.
    – JPhi1618
    Feb 25, 2020 at 17:09
