I have this at home: Glue
and I need to solvent-weld these abs drain piping:
Can I avoid purchasing solvent cement? Or would that present some problem?
Thanks.
Sign up to join this communityAccording to the marking on the tube it's rated for both EN14680 (Adhesives for non-pressure thermoplastics piping systems) as well as EN14814 (Adhesives for thermoplastic piping systems for fluids under pressure).
The product datasheet I found says:
Tangit PVC-U is suitable for producing tensile stress resistant connections between pipes (e.g. drinking water and gas pipes) and fittings made of PVC-U* in compliance with the recommendations of the German Plastic Pipe Association. *PVC-U = rigid PVC
But - on page 2 it says:
The recommended product for pipes made of ABS is Tangit ABS
My best guess is that it'll probably work sorta-kinda-ok-ish, but I wouldn't use your PVC-U on ABS pipes except as a last resort in a non-demanding application.
