I have a can light (recessed light) that I need to convert to hanging a pendant light. The conversion kits have you plug into the socket, and I am hanging a dimmable LED fixture with a wall dimmer instead of a switch.
Is there any issue with it being dimmable since you're not directly wiring it to the switch? i.e. wiring to the socket adapter -> screwing into the original can light socket.
