How can I take care of this bathtub blemish? It is as if a small part is missing, less than an inch in size. Also, I have a couple scratches that I'd like to hide, but I wasn't able to get a focused picture on them. Thanks,
1Looks like a fiberglass tub - is that right?– JPhi1618Feb 21, 2020 at 21:07
2Does this answer your question? What is the best way to repair a cracked bathtub?– isherwoodFeb 21, 2020 at 21:11
I think it’s hard to tell if acrylic shell or gellcoat both have chopped fiberglass sprayed form. I would go with acrylic. 2 part epoxy sanded down with a smiling sticker to hide it.– Ed BealFeb 21, 2020 at 23:01
I don't know if it is fiberglass. I know it seems a bit hollow to the hit. I tried to discover this with Google searching.– Matthew KooshadFeb 23, 2020 at 0:53
1 Answer
This might sound crazy but what I have been seeing used in a residential and commercial setting of remodeling, is Bondo.
I have seen it come with some really great results.
I have seen it used on everything from wood to metals.
Simply apply it, Let it dry and sand it smooth.
