I’d like some advice to connect the main panel to the conduit. It’s 2” conduit to the outside which connects to a detached garage. The problem I’m not sure of is how do I go from this LB box to the main panel without hogging out the entire 2x4’s in between the two. It’s 2” conduit because a bunch was given to me. I’m running 3- #4 and 1- #6 through this.
idea
Main panel conduit
  • Can you move your panel two bays to the right, or will it not fit there? Feb 16, 2020 at 22:05
  • @ThreePhaseEel technically I think the panel could be moved but if that’s the best option I think I’d move the hole and the conduit. I used a old hole from the single branch circuit. Between the panel and my current conduit is the communications stuff (eg ATT & Comcast) so it would require more digging outside around those non electric cables.
    – Dano0430
    Feb 16, 2020 at 22:40
Given that you're using "free" 2" conduit, you have to pay the other way - by basically obliterating your 2x4s to make room for it.
Another option is to downsize the conduit where you go through the 2x4s. Your wires can fit in 1" Schedule 40 PVC conduit (using Sch 40 is OK here). You might consider bumping to 1-1/4 or 1-1/2 EMT conduit, if your existing holes have the space, because that would allow upsizing your wire - either for more amps or going aluminum wire to save money. You definitely shouldn't waste money on copper feeder wire, unless aluminum just won't fit.
  • Thanks. I already have the mentioned wires in copper. I can use emt. The pvc has such a large oversized that the lb box sticks way out of the wall. I can get a small box and drill holes for 1-1/4 emt. That still takes a lot out of the studs though. But far less than the 2” pvc
    – Dano0430
    Feb 16, 2020 at 22:51
Could you cut back the two 2 inch conduits on the right of the panel and set a PVC junction box (ON THE OUTSIDE) and then run conduit over and LB through the wall inside to the back of the panel?
And if you wanted to add any additional circuits in the future, you would have access to a junction box on the outside to come out of. Remember to seal and close (caulk) all the holes and pipes extruding to the outside.
Or just 90 over both 2 inch PVC conduits and then go through the wall into the back of the electrical panel. You will have to re pull new wiring though because the existing would be to short.
    Welcome to StackExchange. This is not an "internet discussion forum" in the way you are used to. It is a question and answer site. If you prefer the discussion forum style, try diychatroom.com. 99.99% of the time you should have one answer per question. You can edit your answer when you wish to add content. Also, you now have enough reputation to add a comment below a question or answer, which is where to ask for clarification. If you think you'll stick around for awhile, register an email and set up a password, that way you'll keep your reputation! Feb 17, 2020 at 0:57
