We have a 20 amp circuit running from the service panel to our laundry room, where we have a gas washer and dryer on 120v.
We've not had any problems with the electrical system in our house since we bought it (7 years ago), at which point we upgraded the service panel and had some new circuits runs.
Today, when using the washing machine, it suddenly turned off, and would not turn back on. I went to the service panel - none of breakers had tripped. I manually turned the garage breaker off, then back on, but the washer still would not turn on. Back in the garage I used a multi-meter and found the voltage to be at ~60v (whereas other receptacle in the house correctly report 120v). If I plug in a lamp in that receptacle and turn it on, the light shines, but dimly.
What's going on here? What would explain the sudden voltage drop? It's been years since we've had any electrical work done and it's worked flawlessly until just today. Does this indicate a short somewhere in the wiring? An issue at the service panel?
Thanks
