The city responded to a water main break down the block last night. When they shut off the water to repair it, a bathroom faucet started to drip at the spout. It was more like a thin stream/dripping. I opened and closed the faucet; no difference in the stream open or closed. This is a second story faucet. When opening other faucets on that level there was no pressure at all. The water supply is back on now and the faucet is not dripping. I figure this is an early sign of something. The fixture is about 25 years old. Could you please comment on what could be wrong and what I should do about it. Thanks for your help.
  • Hi! You have a couple of unregistered accounts. Please consider registering one of them, then merge them together, which will allow you to edit and comment on any of your posts. Thanks, and welcome to the site!
    – Niall C.
    Feb 14, 2020 at 15:51
Single handle faucets or washer less actually use the pressure as part of the mechanism to stop the flow, when the pressure is reduced two far some start dripping. I usually have standard rubber washers and several sizes of O-rings for washerless faucets to replace when they start dripping, if after the pressure is restored the drip has stopped I would not worry until it starts dripping with normal pressure. Usually once a washerless starts dripping you have months to repair.
