Brown & black as in pic, i have connected with connector & left it, red connected with light Live ( brown) & blue with blue ( N), in switch there are Red & Black wire & Black showing live ( tester )... some how light is not coming. Please advice thanks
1Can you turn the main power off, dust away all that spooge, and take another picture? Do you have a voltage tester and do any wires show live? If you connect the lamp, does the neutral (blue or black) show live?– Harper - Reinstate MonicaFeb 12, 2020 at 16:30
Thanks for reply, that was pic i took while disconnecting old light, far right are brown & black.. than Red which is connected to Live in new Led light..than blue with Blue ( N).. in wall switch there is Red & Black wire.. Black showing Live ( with tester )– INDERDEEPFeb 12, 2020 at 16:46
1Yeah, I don't think this is a "color of wire" sort of problem. I'm more interested in seeing the condition of the wires and binding posts.– Harper - Reinstate MonicaFeb 12, 2020 at 16:58
I have connected to new connectors. In ceiling rose to light...– INDERDEEPFeb 12, 2020 at 17:00
Light was working perfectly fine, just wanted to connect new Led. In process old connector crumbled. So have used new ones– INDERDEEPFeb 12, 2020 at 17:02
Add a comment
