O have a new propane wall heater in my new shop with a new low pressure reg. The heater works well during the day but when I go out at 8 am the heater is out pilot is out also. I live at 7030 feet, I leave a window open approx 3/4in.. the temp is around 27deg at nite.
  • Is there possibly water in the line from the tank to the heater that may be freezing and blocking the flow of gas? – jwh20 Feb 12 at 16:17
  • It would be helpful to know the make and model of heater. Is it vented or unvented? Your comment - I leave a window open approx 3/4in.. leads me to believe it's unvented which can be a problem at high altitude. – HoneyDo Feb 12 at 16:54
  • Hello, and welcome to Home Improvement. Unfortunately, we'll need more info before we have any chance of helping you. Please take our tour so you'll know how best to participate here. – Daniel Griscom Feb 12 at 17:30
  • Has it been re-jetted for the altitude? (I assume you probably know to do that). A volume of air only has 3/4 as much oxygen as at sea level, so it matters. – Harper - Reinstate Monica Feb 12 at 19:32
  • are you sure it's propane, and not butane, in the tank? – Jasen Feb 13 at 3:58
