I installed a new tub faucet because the old one had a terrible diverter.
Because the pipe moves in and out (about 1.5inches), it’s impossible to get the new faucet to fit tight against the tub. I also can’t caulk any gap because the movement will break the seal.
I have a plan to fix it and I want to make sure this is the best plan.
I’ve opened up the wall to strap down the pipe.
This is what it looks like inside:
The pipes run along the inside of the studs so I cannot screw in a strap.
So here’s my plan and I’d love feedback. I plan to add a 3/4” thick piece of scrap plywood behind the pipe. 3/4” is the distance between the tub and pipes.
Then, I’ll strap the pipe to this scrap plywood with this:
That will keep the pipe from pulling towards the inside of the tub.
Then, I’ll toenail a 2x4 between the studs. Finally, I’ll screw through the 2x4 into the 3/4” plywood.
Is this over-complicating things?
