My kid threw small cars into the toilet and opened the water, we tried to open the clogging with pompa and it didn't help ... how can you fix or call a professional?
  • 6
    How do you feel about ... ... reaching ... "in there"? – Harper - Reinstate Monica Feb 9 at 9:42
  • 4
    What is "pompa"? Do you mean a plunger? Reach on in there. You're on a DIY site, so do it yourself. If that doesn't help, detach the toilet and turn it over. That's also a we'll documented DIY job. – isherwood Feb 9 at 12:33
    might be able to use a magnet on a string for die-cast cars. – dandavis Feb 9 at 20:51
    Quit with the plunger, that's only making it worse. But it might work if you depress it slowly and then pull back real fast. Then you reach in there. You will get sprayed or you're not doing it right. – Mazura Feb 9 at 22:25
  • Gives new meaning to "My car is a crapper." – DMoore Feb 10 at 5:20
A wet dry shop vac pushed into the toilet trap while turned on may grab the cars I have actually done this several times some times they get stuck in the vacuum hose sometimes hanging on at the opening. Try putting the hose in several times until no cars come out, if you come up empty they may be in the pipe below.
| improve this answer | |
