I'm using 2x4 timber cleats to support the treads for a set of stairs going up to a deck. The stringers are 2x10 and both the stringers and 2x4 are pressure treated pine. What would be the best size and type of fastener to use? I was planning on using M10 carriage/coach bolts.
You're supposed to figure that out from the load table mumbo jumbo.
TABLE 9.14 LAG SCREW (BOLT) CAPACITY FOR SINGLE SHEAR CONNECTIONS (LBS.), page 69, Chicago deck code, PDF.
3/8ths (M10) is the middle of the road; it's better than using 1/4" or 5/16". Use stainless steel fasteners. You must pre drill your holes for cleats. Ideally it's an actually cut stringer; notice how cleats aren't even an option.
Seems like I have 2 options: coach bolts or structural screws. I would think that coach bolts would be the better option.– user82609Feb 10, 2020 at 22:04
This article states the usual method is to use four #8 x 3" screws - I am going from memory but I believe that's what I have used in the past. That's quite a bit smaller than what you're planning.
More recently, I have used the angle brackets made by Simpson Strong Tie and others which are made for the purpose.
I prefer the way these look and there won't be a question on inspection. The cost isn't a big deal if it is just a few steps. If there are a lot of steps it adds up. There is no doubt the cleats are strong, as long as the wood remains solid.
Yes, the brackets would be better but they're not available where I am. A #8 screw is only .164". That seems a bit on the small side to me.– user82609Feb 12, 2020 at 20:52
