I have a tiny house that I've just put some drywall up in. I am partial to the look and feel of Venetian/lime plaster, but since the house will move periodically I want to be sure it won't crack too much.
Here's a person who put lime plaster into their tiny house: https://www.youtube.com/watch?v=maMG1T8_u4I
He does comment on how it cracks when he drives it at about 5 minutes.
Is there a natural additive that will help prevent cracks/make the plaster somewhat more flexible?
I'm open to experimenting too :)
    how are you measuring natural?
    – Jasen
    Feb 9, 2020 at 5:27
  • They used to put horse hair in plaster. Feb 9, 2020 at 5:29
  • @Jasen Also flexible but generally something non-toxic and compostable.
    – Joe B
    Feb 9, 2020 at 5:29
  • @SteveWellens That's pretty cool! Would any kind of hair work for this?
    – Joe B
    Feb 9, 2020 at 5:30
    I don't know. Probably not hair from blondes, they have really fine hair. Try google. Feb 9, 2020 at 5:32
Think panels. The reason wood works so well is that each board can move 1/16” or so and the wood doesn’t crack or come apart.
Install gypsum board with plaster in panels that are allowed to move a bit and they won’t crack and fall apart either. You’ll need to experiment to determine the maximum size panel that will work in your case.
In addition, stiffen the under carriage so the entire building will not flex and twist during moving.
I’d use the “flexible” gypsum board panels (with your lime plaster over.) See USG 1/4” panel. Here’s an article about it:
https://www.usg.com/content/dam/USG_Marketing_Communications/united_states/product_promotional_materials/finished_assets/sheetrock-gypsum-panels-quarter-inch-flexible-submittal-WB2128.pdf
  • Im imagining that you put the plaster over the drywall in rectangular sections that resemble bricks. Is this correct? If so, how would you acheive it? couldn't find it on google, but maybe I don't know what to google.
    – Joe B
    Feb 9, 2020 at 22:28
  • @JoeB Yes, directly over the “flexible” gypsum board. I’d recommend panels that are square-ish, but they don’t need to look like bricks. I’m thinking plaster looking, but in sections up to 8’ x 8’ or so.
    – Lee Sam
    Feb 9, 2020 at 23:51
  • would you recommend using mesh lathe for this application?
    – Joe B
    Feb 10, 2020 at 2:47
    @JoeB Not sure if mesh isn’t better or not. I know Venetian plaster is more flexible than gypsum plaster or thin set plaster. (Thinset plaster has a very hard finish on the surface and you probably don’t want it.) I’d contact a plaster association for assistance, then experiment. Here’s one: mnlath-plaster.com
    – Lee Sam
    Feb 10, 2020 at 4:43
