I am at my breaking point on how to take this shower handle off. It's a Delta and I need to replace some o-rings in it to stop my leaking faucet. I don't seem to see a set screw anywhere on this thing at all. I took off the backing plate to still find nothing.
How do I take this thing off so I can access the inside?
It's a Delta Monitor and it says 13/14 Multichoice on it.
  • Hello, and welcome to Home Improvement. If an answer is helpful, please click the large check mark next to it to accept. And, please take our tour so you'll know how best to participate here. Commented Feb 9, 2020 at 14:58
11
Using a flat plastic tool (like a putty knife), pop off the small cap at the end of the lever (handle). Then use an Allen wrench or well-fitting screwdriver, as appropriate, to loosen the attachment screw, which may act as a set screw for the lever base.
