Help! I was replacing my overflow cover when I realized the overflow pipe is missing it's gasket. This is a brass pipe with machined threads on the outside. The top of the overflow very slightly peeks into the tub (see pics)
I noticed some disintegrated plastic around the thread, so something was screwed on at one point. The local plumbing supply couldn't figure it out, and I can't find anything online.
  • In my experience the gasket is on the outside. You can't see it from this angle...
    – brhans
    Commented Feb 8, 2020 at 21:22
  • I poured a little bit of water into the space between the tub and the pipe and I felt it come out...would you have any idea what type of part I need to fix this? I've seen the standard ones that go in btwn the tub and the pipe like a compression. But don't think that would suffice here...
    – John
    Commented Feb 8, 2020 at 22:44
    Well, yeah - it would do that - because you've got it all loose... Once you screw the front on tight it's supposed to pull the gasket tight against the back of the bath to seal. Here's a video of a guy replacing the overflow gasket and although his has 2 screws to attach the cover, you can see how it's supposed to work. And you might want to remove all that old sealer from around where the cover goes (and do not apply more when you put it back together).
    – brhans
    Commented Feb 8, 2020 at 23:13
  • "disintegrated plastic around the thread" - that was the rubber grommet that goes between (behind) the tub and the drain. Yours has slots for the cover plate screws just like everyone I've ever seen, which you removed, right? Picture of the cover plate?
    – Mazura
    Commented Feb 9, 2020 at 3:09
  • @brhans - inside of the wall; 'outside' of the tub. (I thought you had it backwards. It was just ambiguous)
    – Mazura
    Commented Feb 9, 2020 at 3:14
