Using my AC with the front panel/lid just a little bit open prevents it from doing a horrendous sound.
Is it ok to use it like that?
Thanks!
    Yeah, I've done that myself. As long as that door normally opens. Feb 8 '20 at 7:48
    I don’t see a problem it may affect the efficiency . Did you check the screw on the squirt cage blower? If that is loose and it keeps free spinning it will ruin the shaft and a new motor will be needed if that is the cause.
    Feb 8 '20 at 15:54
  • i have note done that, can i do it myself?
    – Bernardo
    Feb 10 '20 at 4:47
  • @Harper-ReinstateMonica thanks
    – Bernardo
    Feb 13 '20 at 2:00
