In my bedroom, there is a wall switch that controls a ceiling fan. I recently installed a wireless remote controller in the canopy of that ceiling fan so I could turn it on and off from the comfort of my bed with a remote dongle. Because I primarily use the remote to turn on and off the fan, I have no need for the wall switch anymore.
I could completely remove the need for a wall switch by splicing the line and load wires together and putting a plastic plate over the switch box. However, I conducted some research and found that the NEC prohibits lights from being controlled primarily by a "pull chain" type of mechanism. While a remote and pull chain are not exactly the same, if I were to remove the wall switch, I would no longer necessarily have the ability to turn the ceiling fan on and off from the entry of the room (if I left the remote in my drawer, for example).
Strangely, the remote control comes with a holder that can be installed over the switch itself by screwing it into the face plate cover. By installing the holder over the switch, I would effectively be rendering the switch inoperable, constantly keeping it in the "on" position. Surely, The Home Depot wouldn't sell a device that violates NEC code by its intended use.
That being said, would my removal of the wall switch in favor of a remote controller in the canopy of my fan be considered a violation of this prohibition of the NEC?
    You said it's a fan, so go for it. If it was a light, different deal. Certain rooms must have a light that is switchable by a common switch in an expected location. You can have a remote also, but the switch must turn on the light. As for selling things that violat NEC, go try to buy a 3-prong dryer socket or a non-TR recep. Easy peasy. Feb 7, 2020 at 20:47
    @Harper, in the OP post, there is discussion of a light, does the answer you give hold up if the fan A.) also has a light? or even moreso.... if B.) The fan with the light is the only light in the room? My opinion (that's all it is), is regardless of NEC rules or best practices, I would never want to trust the ability to turn something on and off solely on the remote and nothing more. Granted, you have a breaker, but 2 cents, thats yuk.
    – noybman
    Feb 7, 2020 at 21:10
  • I agree if there is no light, many times lights and fans have 2 switches , so using a device that controls the light and fan remotely and eliminating the switch would violate code, with 2 switches it would work fine and be code compliant.
    Feb 7, 2020 at 21:17
    @noybman If that's the only light in the room, it needs to be on a real switch. Having a clever hanger that lets you store the remote at the switch is not the same thing, UL will list lots of things that violate Code if used in certain ways, because their bailiwick is product safety not product use. Many fans are controlled with 2 switches, one for fan, one for light, so the existence of that holder does not imply it has been approved for only-one-switch applications. Feb 7, 2020 at 21:18
    Regardless of NEC, you need a positive way to cut power to the fan to replace light bulbs and clean the fan. You can't rely on an electronic remote with your safety even if the chances of it coming on are very small.
    – JPhi1618
You're correct, there's a huge Code problem with that. It's stated in the Electrical Code, but mainly because it's also stated in the Building Code.
I mean nobody cares about the fan. Have a field day controlling that with your phone or whatever. The core issue is that, as you might have noticed, almost every room has its light switch in an easily anticipated location; you can walk into a room you've never been in before and your hand knows where to reach to find the light switch. Like a lot of really good UX features, that one is subtle and almost unnoticeable. Anyway, you anticipated correctly: You're not allowed to break that.
A core doctrine of US cities is "No hovels". You are not allowed to build a home in which practical occupancy is only possible by you. So "Secret" methods of turning on basic things like lights are not allowed: you can't have all your house's lights controlled by your phone only. Aside from community standards and its effect on real estate prices, the #1 reason is visitors. And the #1 kind of visitor they're worried about is first responders. The EMT trying to intubate you, the firemen searching rooms, and the cop needing to see that's a gaming mouse not a gun.
Home Depot stocking something is about that thing being UL listed, and UL only makes sure the product won't kill you through inept quality or some design glitch that has proven troublesome in the past. Home Depot sells lots of things that are legal in some ways (NEMA 10-30 recep to replace identical recep) and illegal in other uses (to replace a NEMA 14-30). Instructions are part of what UL certifies; and UL will generally try to avoid approving instructions which definitely, always violate the electrical code, but that fan's remote with its on-the-switch hangar would not always violate; it'd be legal in cases where the fan and light are controlled separately. So the instructions/UL would not disallow it.
Depending on how your wiring is laid out, there's a fair chance you can wire the remote to control the fan remotely and leave the light to the switch.
Depending on how cleverly the remote is designed, it could even allow fan+light to be turned OFF by the switch (or remote), but cause the light to definitely come ON when the switch is thrown ON (that is to say, after power loss, its default is to turn the light on). That is the ideal scenario since it provides positive light-turn-on from the switch (to satisfy building codes) and positive system disconnect from the switch also (for safety).
