Is it possible to change the existing light switch In the bedroom to a dual switch and then run the power cables to the loft and install a double socket up there?
Can you provide a picture of the switch box?– JACKFeb 5, 2020 at 0:44
2Sure, it's possible if you have the access etc... how exactly you do it will depend on how the existing wiring is run. Honestly our format here calls for more in-depth questions with more detail... so maybe you can do some investigating and edit your question to add that detail.– Harper - Reinstate UkraineFeb 5, 2020 at 0:49
Can you post photos of the inside of the existing switch box please?– ThreePhaseEelFeb 5, 2020 at 4:10
Hello, and welcome to Home Improvement. We'll need more info before we can help you. And, props for taking our tour before posting; few newbies do.– Daniel GriscomFeb 6, 2020 at 2:21
Add a comment
