I want to create look of giant poured in place pavers on my driveway, using the existing concrete slab. Other than cutting all the way thru the slab and removing giant lines of concrete, then refilling it to desired depth, is there an easier way to do this? I want 3-4” grooves between pavers for that fake turf grass. Don’t think I need more than 1” depth for that. My question is: is there a tool or grinder blade that can cut a wide, shallow channel in concrete that DOESN’T have to be chipped out?
  • A company that specialises in diamond drilling may be able to help, consider contacting any in your area. – Solar Mike Feb 4 at 13:33
    This isn't a DIY proposition. It would take an industrial grinder of a very specialized nature to move that much material and leave clean lines. Even sidewalk grinders use a roller that can't cut channels that narrow. You could rent a rolling diamond saw, but you'd have to cut the sides of the channels, then cut many times between. It would take days of constant cutting. – isherwood Feb 4 at 13:54
  • I think you meant cut channels that wide , even a masonry grinder with a heavy disk will be 1/4” at best. The idea sounds interesting but I doubt it would be realistic and may cause your slab to start breaking on the cut lines. I like thicker driveways but I know quite a few contractors that use a 2x4 so the slab is only 3-1/3 thick. Cut an inch out and now it will break up. If thicker it may hold up. – Ed Beal Feb 4 at 15:39
Put a 1" topping on your slab. Leave 3" grooves out of the topping
| improve this answer | |
  • This is probably the easiest solution. BUT it assumes that the slab does not currently butt up against something which cannot afford a one inch rise (foundation with siding) or if the slab transitions into something which is at the height of the original slab (like a driveway). – MonkeyZeus Feb 4 at 14:30
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably take our tour so you'll know how best to contribute here. – Daniel Griscom Feb 4 at 14:40
  • Short answer, but I think it's the right concept. Removing a strip is way too difficult and could harm the structure. Adding "poured in place pavers" is the best way to get the look of poured in place pavers.... – JPhi1618 Feb 4 at 20:45
