In the photo above you can see that a pipe was put through a 2x4 and that the 2x4 splintered/cracked somewhat as well. This is framing a bathroom in the basement. On the Framing perpendicular there is a steel beam support the house.
I don't think that the framing around the bathroom is supposed to be a major load bearing wall. Is this 2x4 okay as is or should I have it replaced?
