Can a saddle tee legally be used to tie shower drain into 4 inch main drain in the state of Illinois? All plumbing is PVC.
Generally speaking they're prohibited inside buildings. You'd use a pair of shielded couplings and standard sanitary tee. I'm not familiar with Illinois and any deviation from common code, though.– isherwoodFeb 3, 2020 at 15:17
Add a comment
