I have a chain drive garage door opener. The sprocket on top of the garage door opener broke off so the chain isn't connected to the garage door opener anymore.
I want to re-use the garage door rail I have because it's one piece that's 6 or 7 ft long (I didn't measure but it's about that long). Looking at the chain drive openers I can buy at Home Depot, it looks like the rail is in pieces since the box is like 2 ft long.
Assuming the length, load strength, etc. is the same for both the one piece rail and the multiple piece rail, is it a good idea for me to reuse the old rail?
I'm asking because I want to install less things if I can help it. Also, the idea of a single solid rail sounds more structurally sound than a 5 piece rail that's screwed together.
