What do I need to hook up a portable washer to the regular hook up for a normal size washing machine. I cannot get a new washing machine in the laundry room area so I have to go with a portable. The hot and cold pipes are there but portables only have one inlet hose.
Is there still an old washing machine in the laundry room?– Michael Karas ♦Feb 1, 2020 at 16:41
Do the directions for the portable suggest that you would be connecting to a typical kitchen faucet? With the kitchen arrangements you can pre-select the water temperature depending upon how you set the hot/cold mix.– Michael Karas ♦Feb 1, 2020 at 16:44
This has been asked and answered. diy.stackexchange.com/questions/27581/… It seams like a lot of work to convert it when you could POSSIBLY find a machine that will fit through your door, but i do not know why you can not fit a new machine?– Alaska ManFeb 1, 2020 at 18:31
Hello, and welcome to Home Improvement. We'll need more info before we can help you. And, you should probably take our tour so you'll know how best to participate here.– Daniel GriscomFeb 2, 2020 at 0:27
Add a comment
