My bedroom is using double glazed windows with great performance on soundproofing noise made by cars outside.
Regarding little girls screaming and dogs barking, double glazed windows do reduce part of that kind of noise, unfortunately the remaining noise that passes through the window is not very loud but still clear and annoying.
What could I do next?
12
  • 4
    Hi. You really need to slow down on the questions, especially open-ended ones like this; you're starting to overload the moderators. You still haven't taken the tour; please do. Feb 1, 2020 at 14:57
    @LeeSam If this is a good question, why haven't you answered it? And, if you feel I'm not doing a good job reviewing, how about you put a little effort in and do a few? Perhaps one? Feb 1, 2020 at 16:20
    @LeeSam Do a few reviews. Questions and answers get points; reviewing gets nothing, but this site fails if people like me don't put in the hard work. I've done 16k+ reviews; you've done exactly none. So, rather than criticizing my reviewing, how about you put in some effort and do a few yourself? Feb 1, 2020 at 17:12
  • 5
    @LeeSam People on StackExchange are expected to "meet us halfway" and show reasonable effort and research in working their own problem, which should be a genuine real world situation (talking to you, Sean of aviation.se). Otherwise it distorts the quality and general usefulness of the question. OP ignores that because OP's core motive is to vent/rant/fantasize escape from/commiserate about an unsatisfactory living situation. A forum or chatroom would be better for that. Feb 1, 2020 at 20:31
  • 4
    @LeeSam You missed (or chose to miss) the bulk of what I said, which I consider disrespectful. Like I said, SE's standard is that people should make an effort. Feb 1, 2020 at 20:58
You could add operable shutters outside, and heavy sound deadening blackout shades inside.
Even hanging heavy curtains would help.
There are two kinds of “sound control” problems: 1) airborne sounds, and 2) impact sounds.
1) Airborne sounds (talking, tv, etc.) is the easiest to control.
2) Impact sound (closing doors, heels clicking on floor from walking, etc.) is much harder to control, but sounds like this isn’t your problem.
In order to control airborne sound various types of materials are added to inhibit sound waves from passing through walls, windows, etc.
Just as Jack indicated, adding items outside over the window will help DEFLECT sound waves and hanging items over windows inside will help ABSORB sound waves.
Also, adding a storm window (another pane of glass) that is A) a different thickness than what is currently in your windows, and B) installed at a slight slope to the other panes will reduce sound transmission, C) caulk perimeter of window, D) infill around window rough opening, and E) cover electrical outlets on the wall.
A) Using various thicknesses of materials will stop various wave lengths and reduce sound. Using 1/4 “ plate glass instead of the 3/16” sheet glass that is probably in your windows will stop different sound waves.
B) Installing the new storm window at a slight angle to the other panes creates an air space that varies. This will eliminate different sound waves too.
C) Make sure there are no air gaps around the perimeter of the new storm window by caulking the perimeter.
D) When windows are installed, they are installed in openings slightly larger than the window. This creates an air gap around the perimeter. If you remove the inside trim around the perimeter, you can access this gap and infill it with batt insulation or foam the gap to stop the transmission of sound. (Be careful not to use an expanding foam or it could crack the glass.)
E) Often sounds will travel through electrical outlets, because it’s the “weak link” in the wall. Be sure to cover all outlets, switches, etc. that are on this wall.
  • Re D, properly installed windows don't have those gaps, is that a cowboy method?
    – Solar Mike
    Feb 1, 2020 at 19:07
  • @SolarMike What does “cowboy method” mean?
    – Lee Sam
    Feb 1, 2020 at 19:33
