I have a living room/dining room area that each only have 1 light - see photo. The light over the table in controlled by its own switch, and the ceiling fan/light is controlled by another switch at another area.
I would like to add some recessed lighting to both zones. I'm thinking 4 in dining table area and 4-6 in the living room area.
How do I run the wiring in each case? I would think that I would disconnect existing light, make new holes for new recessed light and pull existing wire back to the closest hole to light switch, then try to run all 4 recessed light and existing dome light in series.
I have not done this before and have watched a ton of videos, read on the forums, etc, but still not sure how to best do this project. Looking for any advice you all might be able to share.
