I've tried looking for guides, but I haven't seen any other lights like mine
It seems like there is a cover over the bulb but I haven't been able to remove it and even if I could I don't think the bulb could fit out.
I've tried twisting the white case but there is no movement.
I can't see any clips
There are some screws, but I haven't seen any other fittings that need anything unscrewed to get to the bulb.
The second picture shows how far I am able to pull the fitting out
    Have you tried to separate the white cover from the base by just pulling it down? – JACK Jan 21 at 16:50
  • It might require some prying to get off if you haven’t tried that yet and you can’t find any other way I would try prying it loose with a flathead screwdriver – JIMMYPlay Jan 21 at 16:50
  • Perhaps that cover twists off – Solar Mike Jan 21 at 16:57
    i have the same ones in my kitchen. there's no twisting at all, everything pulls apart. there's a tight-fitting sleeve bracket over the GU10 bulb that slides off. they can be quite stuck in there, watch your knuckles when yanking. i would upgrade to LED replacements. – dandavis Jan 21 at 17:43
    @dandavis, sounds like an answer. – JPhi1618 Jan 21 at 18:20
