Installed a new furnace humidifier to replace a non-working(probably never used) vintage humidifier 14 days ago in a new place I bought.
Confirmed a small gap let a slow drip from condensation that is now visible in spots near the bathroom ceiling(discovered wet spot 1 day ago. Didn't notice spots when replacing bathroom lights 3 days ago so likely very recent).
Wood floor/ceiling in furnace humidifier crawl space above bathroom shows moisture in some areas but it dries pretty quick(it's hot/dry in that tiny room but seeped down floor cracks and wall opening: no permanent warping of wood or even long term moisture marks despite being slowly soaked regularly for 1-2 weeks). Some small yellow water stain damage on wall next to furnace near
Photos: https://photos.app.goo.gl/iHwGydbetBBoZ3ku8
FYI: the white spots in the wood floor are from saw dust. There is no visible yellowing/dirt on the drywall and it seems to be rigid. Moisture was more visible but turned off humidifier last night(dried very quickly).
I'm getting a mold test pronto, humidifier turned off, sealing the ductwork gap, dehumidifier(?) but worried about long term mold risk and if I should get mold inspection? Do I even need a dehumidifier rental for the bathroom if humidity in my place to 15-25 without the humidifier on? Wood has dried completely in a few hours already.
I use an ecobee thermostat to control the humidifier/furnace so below are stats:
Humidity in the place has never risen above mid 50s(all window corner unit in chicago winter) and usually hangs around 35-48(according to sensors) for the past 2 weeks. Max I've seen it ever is 53(temporary after shower or dryer was run). The bathroom has a humidity sensor controlled fan that turns on for 30 minutes if humidity ever hits 60%+ in the room. Indoor temps hover around 63-75(58-63 at night and most of day when away; 68-75 when at home).
EDIT: My furnace air filter is rated MERV 10(installed 2 weeks ago) so most mold spores if in the air were likely caught
    What's the question, exactly? Mold spores are everywhere, floating around in the air. Some probably grew somewhere, and it's probably not an issue if things are dry. – isherwood Jan 20 at 17:33
  • I would race to the store and get a mold test only if you want to wast your $. I agree with Isherwood and any spots you see may dry out fine in a few weeks. Even if there is mold most are not a health problem, het some hydrogen peroxide if you want to do something, 3% hydrogen peroxide and water will kill mold, I always have a fresh quart of 30% great stuff and no stink like bleach has. Just remember always add acid when mixing to prevent an exothermic reaction. – Ed Beal Jan 20 at 19:17
  • The small dimple in the photo looks like a screw that was not properly mudded, the large wet spot may take 3-4 weeks to fully dry don’t mess with it, possibly have a fan blow across that area. The Sheetrock may show a stain from the wood and dust in the floor that the water picked up if it takes a month to dry wait another month if you want to paint. – Ed Beal Jan 20 at 19:30
  • @isherwood, how badly is the screw up? Based on comments, not so bad to ruin my walls or worry about mold everywhere.. I can't believe an HVAC guy did the duct work for the old humidifier so bad: Massive gaps everywhere. – deek Jan 20 at 20:56
  • Hello, and welcome to Home Improvement. Unfortunately, any answer to this question will be a matter of opinion. Please take our tour so you'll know how best to participate here. – Daniel Griscom Jan 21 at 13:40
