The two lights are wired to one switch. The fans are wired to the other switch. Can I install a dimmer just to control the lights and use a one pole since there is only one switch?
Yes you can do that. Turn off the power and remove the two wires from the old switch and hook them up to the two terminals of the dimmer.
| improve this answer | |
