Reference: Can I convert a 3-way switch that switches half duplex outlets into an outlet?
My answer to the referenced question involves removing the red wire between two 3-way switches and converting the bundle to an always hot bundle. Essentially making a 14-3 bundle do the job of a 14-2.
What is the proper way to deal with the extra wire?
Cap each end with a wire nut and leave it in its junction box.
Do not trim away the ends of the wires. That could confuse a future maintainer, and someone might find a use for that wire someday.
If you maintain infrastructure documentation on your home, add a note describing the abandoned wire.
If you do not maintain infrastructure documentation on your home, start now. Begin with a note describing the abandoned wire.
