My heater stopped working. It started after I put the fan on. Then it was running for days after I stopped the fan but suddenly stopped working. Once again I had to put on the fan to start the heater. Anyone know what this could be?
It's not clear what type of fan or heater you're talking about. Central heat? Space heater? Is the fan a part of the heater? – JPhi1618 Jan 14 '20 at 15:49
Thank you and sorry. It's an oil heater and yes the fan is part of the unit. – Jess Jan 14 '20 at 16:01
Central unit for my home. – Jess Jan 14 '20 at 16:12
Hello, and welcome to Home Improvement. What make/model unit is this? And, you should probably take our tour so you'll know how best to participate here. – Daniel Griscom Jan 14 '20 at 20:45
