A Florida HOA electric bill doubles from $200 to $400 per month. Powered items for the pool comprise LED lighting and a pool pump. The electric circuit is for the pool.
Is it reasonable to start the investigation with the pool pump as the culprit?
If the pump is the culprit, what conclusions can one make regarding the excessive use of current?
