I've been trying to get this three way setup working for a few days now.
The wiring diagrams that came with the kits are not consistent and when I wired according to the diagram I was not able to get the lights working at all.
Current behavior: WiFi Enabled Leviton DW6HD turns the lights off and on as expected. Remote Leviton DD00R-DLZ switch on the same circuit turns the lights off as expected. However after turning the circuit off the remote switch ceases working.
Expected behavior: Remote switch works to turn on lights after turning the lights off.
This is the WiFi enabled DW6HD switch as it is currently wired. Wired DW6HD
This is the WiFi enabled DW6HD switch unwired (showing for reference). Back of DW6HD
This is the matching Remote DD00R-DLZ switch as it is currently wired. Back of DD00R-DLZ
I have also tried the following configurations:
  • Both Black wires on BK screw with Red on YL/RD [ Lights turn off with remote switch but does not turn on]
  • Red on BK screw with both black wires on YL/RD [ Lights turn on and off with WiFi enabled switch, remote switch shows online but does not do anything]
  • Red on BK screw with taped black wire [ Lights do not operate on remote or WiFi enabled ]
  • Red on BK screw with un-taped black wire [ Lights do not operate on remote or WiFi enabled ]
  • Red on YL/RD screw with taped black wire [ Lights do not operate on remote or WiFi enabled ]
  • Red on YL/RD screw with un-taped black wire [ Lights do not operate on remote or WiFi enabled]
Edit: As requested here are the images of the inside of the boxes.
This is the box with the DW6HD WiFi enabled switch, the lines coming in from the bottom are hot from the outlet on the other side of the wall (an electrician that was over here trying to help told me that when we were testing it). Box with DW6HD
Here is the box with the remote DD00R-DLZ switch. Box with DD00R-DLZ
    Can you post photos looking into the backs of all boxes involved please? Commented Jan 12, 2020 at 18:17
    Yeah, seriously. Most newbies tackling a 3-way switch project assume wire colors carry all the relevant info. Actually they carry no info at all and it's all in the grouping and positioning. That's why we need to see the photos of how these wires connect in the back of the box. Commented Jan 12, 2020 at 19:36
    Oh, and if you're going to attach that red wire straight-in, it needs to be underneath that little brass plate (similar to how the black wires are). If it's above the brass plate, then you must shape it into a J-hook like a traditional screw. I can't 100% see what you did. Commented Jan 12, 2020 at 19:40
  • @ThreePhaseEel I added the images as you requested.
    – zmanc
    Commented Jan 12, 2020 at 20:48
  • @Harper-ReinstateMonica, I was planning to dress the wires when I had everything working, at the moment I took these pics I was just trying to get everything working, thank you for the feedback though on making sure its under the plate. I've updated the images to include the back of the boxes as well as some additional context.
    – zmanc
    Commented Jan 12, 2020 at 20:49
As you seem to know, the "bare" wires, along with any green or yellow/green wires, are always and only Equipment Safety Ground. They get used for nothing else.
How the 3 wires must be allocated
NEC 110.3(B) requires you install the light switches according to the instructions. This is not optional. Since Reading the Fine Manual is mandatory, you see the "3-way configuration" diagram plainly shows 3 wires (other than ground). Two of their uses are obvious. The third appears to be some sort of communication wire that runs only between the units. So, in the /3 cable between switches, we must allocate the wires as follows:
  • White MUST be neutral. (NEC 210.something) and it always connects to the WH (silver) terminal on both smart switches. (It also goes onward to the lamp). That's done!
  • Always/line/supply hot traverses the /3 cable. The conventional color for that is black, so let's stick to that. This goes to the BK terminals on both smart switches. Done and dusted. We will not revisit this again.
  • The remaining wire (shown in the instruction as a thru-wire) is Yellow/Red and is the communications wire that runs only between the switches. The only wire we have left to allocate is the Red wire in the /3, so that is that. It connects to the YL/RD terminal of each smart switch. I am super fond of yellow tape for travelers, and while this isn't a traditional traveler, its code is yellow-red, so it's too perfect to resist marking with a yellow band!
We have now assigned all the wires in the /3 cable. Pretty straightforward once you figure out which wires are needed, assign tasks to the wires in the wall, and color-code them for purpose.
One last wire to connect: the hot wire to the lamp, which is switched-hot. That wire could be re-marked red, which is the conventional color for switched-hot. That goes to RD wire on the master dimmer. Piece of cake!
Wait a minute! The RD terminal is in one box, and the wire's in the other!
Because the smart switches are not in the right boxes. Switch them.
    Wanted to take a second to thank you for your help and patience. Finally had some time to look at this again on MLK day and after switching the smart switch to the other outlet and getting the wires assigned & dressed everything is working as expected. Cheers!
    – zmanc
    Commented Jan 21, 2020 at 13:41
