I just wanted to know what year did bathroom fans begin being put in houses. The house I grew up in was built in the 20's and didn't have a fan. There was a window.
4I'm voting to close this question as off-topic because it's not about home improvement.– JACKJan 12, 2020 at 17:18
Hello, and welcome to Home Improvement. Interesting question, but indeed it's off-topic here. You should probably take our tour so you'll know how best to participate here.– Daniel GriscomJan 13, 2020 at 1:31
Saw question title on hot network question. First assumed it was an ips.se question....– rackandbonemanJan 13, 2020 at 1:34
The code requires an exhaust fan of 80 cfm for bathrooms with a tub, shower or spa. (See ICC M1507.)
For bathrooms without a tub, shower or spa a window of 3 square feet (of which half must open) may be provided. (See ICC R303.3)
I don't know when it became a requirement but building codes came into effect in 1955. If they were installed then it was by choice since no rule existed before then, that I know of. If an old code book can be found particular to you area, then it could be determined. But back in the day, the code was different area by area. Not greatly but small differences here and there, and still is, through local addendums. These addendums change the appropriate code to fit the local areas better, in some cases.
What I do know is that when the code did require fans in bathrooms, there was an exception if there was a window in the bathroom that opened, then it was not needed.
I agree I think the window has to have ~1.5 square foot opening to not have a fan.– Ed BealJan 12, 2020 at 17:03
Oh, you definitely want a bathroom fan even if you have a window. There are two reasons you want to ventilate a bathroom, one is humidity from the shower. The "open window" method is not reliable for removing humidity, and that gets you mold. As for the other reason, half the time air blows in through the window, pushing bathroom air into the rest of the house - the opposite of what you want!
1And one more reason: If it is 95 F or 25 F outside, you don't want to open the window. Jan 12, 2020 at 21:01
When they were first required by code is one thing, but finding out when people first decided to use a fan to help bathroom ventilation is another - the saying "necessity is the mother of invention" is very apt...
Absolutely buy an expensive fan, one with good bearings and a big motor. They are far quieter than the cheapies. You won't use a bath fan if the noise is deafening.
