I have a 110V air purifier that comes with a 100-240V adapter. Can I still use the air purifier with power input 220-240V? Do I need a transformer or converter? Thank you.
Edit: I can’t find the attachment option :(. This is what it’s written on the adapter 100-240V. 50/60Hz. 0.8A Output is 24V and 1A
This is printed on the air purifier 110V/60Hz.
Does that mean I can use the air purifier anywhere in the world since the power adapter is 100-240V? Auto-switching?
  • you can plug the adapter into 240 V power outlet
    – jsotola
    Jan 12, 2020 at 17:29
    Can you shoot us a photo of the data plate on the adapter? Or at least, can you tell us the current range (in amps) if listed? Jan 12, 2020 at 18:10
  • If the air purifier has 110V/60Hz on it, then you must only run it on 110V/60Hz. The adapter may be rated up to 240 V, but it will not convert that to 110 V. The adapter may have been included so that different shape 110 V sockets can be used. Jan 13, 2020 at 16:39
If the device has a 100-240V adapter, it's a 100-240V device, not a 110V device. Or more likely it's a (some lower DC voltage you have not looked at - should be printed on the adapter, usually in tiny faint type) device with an adapter that is 100-240V
So, you should not need anything more than a way to plug its adapter in to use with 240VAC
  • Thank you for your reply. That’s the confusion. It’s stated as 110V device printed on the item but the adapter is 100-240V. Is the adapter also a converter or transformer? I’m really confused.
    – Chie
    Jan 12, 2020 at 16:40
    Pictures would help to clarify this.
    Jan 12, 2020 at 22:12
  • @Ecnerwal It's almost certainly labelled as a 110V device because the plug that was supplied with the adaptor is a 110V plug. Jan 13, 2020 at 15:22
Yes. If it's rated as 100-240V, you can plug into either 110 sockets or 220 sockets. A good example is laptop adapters. The only tricky part is IF it will fit into the physical holes. Then there are universal adapters as well.
Usually items marked 100-240v are autoswitching, they react to the voltage supplied within the range. It is probably packaged as a 110v because that is the only cord it is intended to be packaged with. If it is marked 110v and the plug configuration doesn't match a standard receptacle then it was packed in the wrong box.
