Home Depot doesn't seem to have 5-gang boxes - can I put a 3-gang and a 2-gang box together assuming that existing wiring reaches as required?
    What, do you have a big Home Depot gift card you have to use up? Any electrical supply house. They'll be cheaper too on this odd stuff. – Harper - Reinstate Monica Jan 10 at 22:53
    If HD is your only option then they can order it for you. --homedepot.com/p/… - If you put two together then the spacing will not be right for the cover plate to line up for all switches. They do make modular ones so you daisy chain several together. – Alaska Man Jan 10 at 23:41
  • @AlaskaMan Type this up as an answer. – JACK Jan 10 at 23:44
    @JACK Let pause a moment for the mans prayer: I'm a man, but i can change, if i have to, i guess ! – Alaska Man Jan 10 at 23:54
If HD is your only option then they can order it for you. Here is one -
They do make modular ones so you can daisy chain several together, I have seen them a lowes but i can not find a link.
You may need to go to a dedicated electrical supply house.
| improve this answer | |
