After trying many options, I've finally found something that might work to reduce drafts and noise through these 1925 historic windows:
MD Foam Kerf Door Insulation Strips on Window
But that latch. Original brass, matches the house, but won't work well with the insulation. Is there a latch style that might be better available in a vintage style?
I went to the foam kerf style because the more modestly size rubber bulb insulation is so stiff it can't make for good compression, given the relatively wimpy single latch on each window. Sticky foam on the casing similarly failed because the gap ranges from zero to 1/4" or more. The window swings out on hinges.
Tight fit
    Please include a wider shot of the entire window and casement so we have enough information to make a suggestion.
    – longneck
    Commented Jan 10, 2020 at 19:15
Why not just add a piece of blocking behind the latch and move the latch receiving hole into the kerfed board? You could paint the blocking black or something that matches the latch hardware.
  • Pretty much what I was thinking.
    Commented Jan 11, 2020 at 15:45
  • See new picture above.
    – Bryce
    Commented Jan 11, 2020 at 19:28
  • Yeah add the 1/2" thick piece of blocking behind the latch which will pull it forward 1/2". Then make the latch receiving slot to match in the kerfboard and window jamb. Commented Jan 11, 2020 at 19:41
  • The hard part is the receiving slot would be right on top of the plastic retainer for the foam, and on top of the weak slot cut for the retainer.
    – Bryce
    Commented Jan 19, 2020 at 20:20
  • That would be true if there was no blocking behind the latch but the new blocking that you put behind the window latch pulls the latch forward into the room putting the new receiving slot in a portion of the new window jamb piece that is sold. Commented Jan 19, 2020 at 22:27
