I couldn't find any examples of my tub drain lever online, so I can't figure out how to remove it. The overflow is leaking, so I'd like to open it up and see what the gasket is like to replace it. On the back of the tub, it looks like there's some corrosion at that point, so that's probably the culprit.
I got the handle loose, but the overflow cap is blocking my access to screws. I can't get the handle out of the assembly, it's connected somehow to the tub drain.
