Hi when I install a new kitchen, should I first take care that the electric wires that are behind the base cabinets will be hidden inside the walls? Is it ok if they will be inside a plastic "tunnel" outside the wall? The plastic tunnel outside the wall is shallow enough so it won't interfere with the cabinets (no need to cut the cabinets back walls)
Thanks.
