Basically I want to build the exact door below, I really like the look of it and don't want to alter it if at all possible. I started to plan things out, but I don't do much wood work. I'm having trouble visualizing the wood sizes I would need to recreate that exact door. My door opening is 32" so I figured a 36.5" door should leave enough over hang on both sides.
Specifically the diagonal and framing pieces. I'm not sure what size piece of wood that is, or if my framing wood makes sense for the diagonal pieces as shown in the picture. I was thinking using a 2x(something) for the framing and a 1x(something) for the diagonal pieces to give the door a little depth, so it's not just a flat door.
Below is the picture of the original door and my plans so far for the pieces. Also, with my inexperience, I was planning on using screws, but also am not sure the size of screw I would use for all these pieces. (ex. #3 1 1/4 in)
