The threaded mounting hole in my metal (based on OPs comment) electrical outlet is stripped; please refer to where the top flat-head screw is in the photo.
As a result, the electrical outlet is not physically stable. How should I fix the problem without hiring an electrician? Thanks in advance.
  • Is the box that the outlet mounts to metal or plastic?
    – SteveSh
    Commented Jan 6, 2020 at 21:38
  • The mounting plate on top is just a regular plastic one.
    – wsw
    Commented Jan 6, 2020 at 21:39
  • In a pinch, I've used a wood screw before, and it worked -- it cut new threads of a totally different pitch into the plastic, and it held fine. The answers below are likely better though.
    – Nate S.
    Commented Jan 6, 2020 at 22:13
    Sorry I misunderstood the question — the box is made of metal!
    – wsw
    Commented Jan 6, 2020 at 22:17
8 Answers 8
Retap to 8-32. This is commonly done by electricians and many of them carry a Klein 6-in1 tapping tool just for that reason. The #8 Flat Head fits just fine under the cover.
Wrap Teflon tape around the screw a couple times.
If the hole is slightly stripped, then slipping some type of material in the hole to take up space might do the trick. A small sliver of card stock or paper or a very thin strand of copper wire (thin like a thread, not thick house wiring).
If that doesn't work or if the hole is actually cracked wide open, you could use glue to hold the screw in place. Superglue will probably work well and will set fast. Epoxy is another good choice, but it can be a bit messy. Even something as basic as wood glue would work to some degree, but that takes a while to dry. Epoxy will be the strongest choice here. The other glues would probably fail after a while or if you tried to plug in something with a very stiff cord.
Glue will make it impossible to remove the outlet, but since the box is broken already, anyone that would replace the outlet would just replace the box as well. They are usually very easy to replace once you've done it a few times.
This is one virtue of plastic boxes. Instead of being a 1/16" thick tab, the screw actually goes into a fairly deep mounting hole.
Now, mind you, this advice is against Code since you're not supposed to modify UL-listed equipment. But I really doubt an AHJ will have a problem with it.
Power off!!! I would mix a quarter-size blob of epoxy, and fold in "fairing filler" (fine sawdust will do) until it barely flows. Sort of like DIY bondo, but a bit thinner - actual bondo is too chalky.
Use a screwdriver blade to trowel it in the hole, and an un-bent paper clip to ram it down. Really pack it in. It's OK to leave a slight hole in the middle; that'll actually help later.
After it dries, pre-drill a hole in it. Make sure it's 6-32 thread (a bolt shear on a multi-strip tool can be used to measure threads). Then google the correct drill size for tapping a hole that size; (#36 for a 6-32 thread) which you won't have, so round down (to 3/32"). That machine screw is self-tapping, so it can deal with a slightly undersized hole.
    Why not just use a #8 sheet metal screw, the threads are buggered already...? Commented Jan 7, 2020 at 5:56
Given that the box is plastic, you have at least 3 options:
  1. Try a slightly larger screw.
  2. Fill the mounting hole(s) in the box with epoxy, drill a new hole, and re-mount the outlet
  3. Replace the box.
If it were me, I would do number 3.
Obviously, make sure the electricity to the outlet is turned off before doing any work.
Edit 1 :
OP says the box is metal. That kind of rules out option 2.
To replace the box, you have to:
1) Remove enough of the wall around the box so you can work. Bigger is better than smaller 'cause you're going to have patch the wall anyway when your done.
2) Disconnect and remove the outlet.
3) Loosen/remove any nuts that hold the wire clamps in place.
4) Remove the box, pulling the existing cables out as you do so.
5) Decide on the style box you want to use. Probably want a new work type and just nail it to the existing stud, assuming you're removed enough sheetrock to do that.
6) May want to pull the cable into the box before nailing the box, if you can do that.
7) Wire up the new output and mount into the new box.
8) Oh yeah, last but not least - patch and repaint the wall!
    I agree, but you might elaborate on how you'd replace that box. It's a daunting task for a DIYer. I've written up the procedure somewhere on this site, but who knows where.
    Commented Jan 6, 2020 at 22:03
    Back in the day one of our standard tools would be a multi-tap driver. It would be a 6/32, 8/32, and 10/32. We would just run it in manually and use the next largest screw. Commented Jan 6, 2020 at 22:17
  • Yes, that was my intent. Do the easy things first!
    – SteveSh
    Commented Jan 6, 2020 at 22:27
  • Would not be to code, but I've used 8/32 lock nuts for this purpose. It's a little tricky to reach behind the stripped hole and get the nut in place, but you can do it if you leave the screw very loose.
    – jbeldock
    Commented Jan 6, 2020 at 22:40
  • Downvoted because there are multiple ways to achieve this job for less than 5 cents and less than one minute without even turning off the power. Why would OP want to take a path that requires buying a new electrical box, plaster repair, buying paint, and either matching it or painting an entire wall?
    – jay613
    Commented May 18, 2021 at 12:48
I had a similar problem with my plastic receptacle but was lucky enough to buy a longer 6-32 screw and screw past the stripped area in the front of the screw hole. $3 fix for me.
I just had this and used a small plastic stucco anchor pressed into the box mounting hole and it held the receptacle tight.
Given that the box is metal:
  1. Get a slip on sheet metal nut or make one that will slip over the metal tab.
  2. Get a plastic box and cut off the top. Use the part with screw hole as a nut behind the metal tab of your box.
    I'm pretty sure that this isn't a metal box the OP is dealing with Commented Mar 14, 2021 at 23:07
  • @ThreePhaseEel In his comment he says it's metal. Commented Mar 15, 2021 at 1:05
  • Ah, you are right, just saw the comment Commented Mar 15, 2021 at 1:33
