I have bought a new motion sensor for my corridor LEDs. The lights turn on fine with it, however, when the sensor is set to OFF, the lights blink indefinitely (a few times per second) and never actually turn off.
It turns out the sensor has a minimum watt requirement of 40W, and I'm quite certain the LEDs use less than that, so could that be the cause of the issue?
If so, how can I easily raise the wattage of the circuit?
And if that's not it, then what could be causing this?
Thanks in advance!
