I was replacing old outlet in my house and came across an outlet that is screwed directly into the studs. Also the stud and the junction box were cut to fit the outlet. The new outlet is too big to fit in this space. I am afraid to put a new outlet in here as it could be a fire risk.
What should I do with this? Should i cap off the wires and put a blank wall plate? Or is there some way I can salvage this and put an outlet in here.
There is a wall (fireplace) to the left and a sliding glass door an inch or so to the right.
