This is the plumbing setup under our kitchen sink, there are two p-traps, one for the kitchen sink and another for the dishwasher that both feed into the drain pipe.
The black p-trap (dishwasher) which is currently broken is leaking at the p-trap. If you were to take a pot of water and dump it into the sink, the water will start leaking almost instantly out of the black p-trap (a lot of water). At first, we thought maybe a clog, so we snaked the drain (25 ft) and came up with nothing, the pipes seem clean, we can't determine why it's leaking constantly (when the water is running).
Does the drain pipe need to be pitched down more? Should we remove the additional p-trap?
