I have a room in a partially finished basement which was done by the previous homeowner which is needing repair to the walls. The house is old (1925), and the foundation is concrete block. The room in question is mostly below grade, and they have finished over the concrete block with some type of plaster, and painted it. I am now running into issues with the material falling off, and paint bubbling, so there is some obvious moisture coming through the wall. My issue is that I am not sure what material was used to finish the wall, it looks almost like drywall compound, but that seems insane to use on an exterior block wall. Here are some pictures of the issue:
More: https://imgur.com/a/rRV5aK9
Any advice on what the material I'm working with here would likely be, and my best approach to fixing the issues I'm having would be greatly appreciated. I'm assuming patching with joint compound isn't the correct solution here.
