I just installed a GE dishwasher. When I turned the breaker on, it had no power. The wall and dishwasher both have 3 wires, black (hot), white (neutral), and green (ground). I have 120VAC from ground to hot, but not ground to neutral. Should I not have 120V between any 2 wires?
10
I aslo have 120V between hot and neutral – Phil C Jan 3 '20 at 3:00
no ... you should not have 120 V between ground and neutral ..... is that the only question that you have? – jsotola Jan 3 '20 at 3:00
Then why would I not be getting any lights or anything on the control panel? It's acting like it has no power. – Phil C Jan 3 '20 at 3:11
I press all the buttons and nothing happens. – Phil C Jan 3 '20 at 3:12
hard wired of plugged into an outlet? did you use a switched outlet? – JACK Jan 3 '20 at 3:23
Show 5 more comments
