I have a 12'x15' room to which I'd like to add cove lighting. There's a second floor above, so I don't have access from above. I do have an outlet along the wall where I can tap off for 120V power, and run any wiring up inside the wall to the top.
I will be building the cove, essentially a T-section. I anticipate about 2" of head room above the top edge of the cove.
My issue is, where can I hide the power adapter that converts the 120V AC house power to 12/24V DC for the LEDs? I suppose worst case I can cut a hole near the outlet for an access panel (or blank wall plate) painted to match the wall, and stuff the power adapter in the wall.
Anyone got any other bright ideas?
